corn stoves
rgriff
01-19-2005 03:28:08
Off the wall question. You fellows that live up north. Have any of you used corn stoves? I'm looking into buying one and trying to find out the pros and cons.
Thanks for any info.
Dale L
01-19-2005 10:00:18
 Re: corn stoves in reply to rgriff, 01-19-2005 03:28:08
I got a corn stove to heat my garage/shop about 4 years ago. It was -25 below here the other day an the temp never dropped below 45.the shed is 36 by 48 and the doors are opened all the time[five kids].The model I have requires you add oyster shells[about two bags a year]. The new generation corn burners are a improvement on the model I have . You can burn higher moisture corn and you don't need to clean them out as much.I have a gravity box I fill up in the fall and it lasts all winter. It's clean heat and I'd rather give my money to the farmers than the oil companies.I'f you can afford the intial set-up there cheaper than gas or oil to run.And there a lot less work than wood.
rgriff
01-19-2005 10:16:45
 Re: corn stoves in reply to Dale L, 01-19-2005 10:00:18
Thanks for all the info. I'll be heating about 1500 sq. ft. I can get the corn from my local farmer for about $2.25 a bushel. Like you said, I would rather give the farmers my money.
Please keep the info coming, I'm learning alot.
25 below!! now that's cold!!!!! !
Where are you located?
Midwest redneck
01-19-2005 14:55:32
 Re: corn stoves in reply to rgriff, 01-19-2005 10:16:45
Dumb question? Do you have to have a flu-pipe for the stove on a corn stove? I would think that you would. Fill me in.
rgriff
01-20-2005 03:15:11
 Re: corn stoves in reply to Midwest redneck, 01-19-2005 14:55:32
No, no flu-pipe is needed. All you need is a 4 to 6 inch pipe that goes straight out the wall behind it. About the same set up as a dryer vent.
ej
01-19-2005 09:26:03
here's a site Link
rebuilder
01-19-2005 06:22:25
Andy Martin:
After L.P. sticker shock 4 years ago I went and purchased one. I had been looking into them for several years but it took $1.79/gal L.P. to get me to act. The model I got was midwest grain stoves. I have been really happy with it, and it has exceeded my expectations. I live in an old drafty farm house and I placed the stove temporarily in the mud room(east end of house). I never expected the stove to be a primary heat souce but that is what it has become. My furnace only runs off an d on when the temp gets below the 20"s. The west end of the house can remain cool, but 75% of house is heated with this stove.
I use about 1.5-2 bu. max per day and sometimes with corn directly out of the field in wagons parked in the barn. Avg. 200 bushels/year.
On the down side you have to change clinkers every 24hrs and there is some dust/ash which can be a problem if placed in a living room. Also if I bought a newer model it would have a dc backup so I could run it off of a car battery during power outages(stove only uses 4-5 amps). I figure though I have already saved the $2300 I invested with gas savings,(Small toddlers and wife like higher temps). Plus it only takes a couple minutes to get the corn brought in with buckets. Much easier and less labor then wood burning.
Andy Martin
01-19-2005 07:19:53
 Re: corn stoves in reply to rebuilder, 01-19-2005 06:22:25
Don't get me wrong, I wasn't trying to make fun of corn stoves. I just thought it would not be a good idea to try to burn popcorn in one.
I've been trying to figure out how to burn square bales and/or old tires for heat. There is a lot of energy in either one and they are cheap to come by. Either one takes forced draft to burn clean and avoid smoke but should probably be outside the house.
If you grow corn the corn stove is even a greater idea, especially if you can use some damaged grain. I can't imagine much of anything like mold causing a big problem, except maybe trying to burn popcorn : )
rgriff
01-19-2005 06:58:39
The stove I am looking at cost about $3600.00. It is made by Harman. Its the newest version. Comes with thermostat, auger, and best of all no klinckers. It has an automatic igniter. all you need to do is fill it up and take out the ash.
scotty
01-19-2005 07:23:29
 Re: corn stoves in reply to rgriff, 01-19-2005 06:58:39
rgriff, Dont know anything about corn stoves, but I can say that Harman is top of the line in coal or wood versions!
scotty
rebuilder
01-19-2005 06:21:54
Andy Martin:
Bob M
01-19-2005 06:06:26
A couple of my friends have corn stoves. They (and more importantly their wives...) seem satisfied with them. They're clean burning and the fuel is cheap - at least it is right now.
Biggest downside is they require electricity to run. When the power goes out so does the heat - unless you've got a backup generator.
Andy Martin
01-19-2005 05:36:43
Don't try popcorn.
