About Allan's 3-point picture
williamf
01-19-2005 06:16:16
third party image
(I couldn't subject this post "Hey, Allan." There are too many of those already. {insert grin})
In a picture you posted below I notice the end of the bottom arms has a catch similar to the one on on a Fasthitch. I remember that all the big Farmalls with which I was familiar ('06, '56 models, after those I fell off the planet for a few decades.)had that. I thought then that these were so that you could take them out and still use your old Fasthitch implements.Is that right, or was it to make it easy to switch between Cat. 1, 2, and 3 implements? Or something else?
Wm
Allan in NE
01-19-2005 06:31:35
 Re: About Allan's 3-point picture in reply to williamf, 01-19-2005 06:16:16
Hi Ya William,
Neither one. They are there to allow easy hookup to the implement.
When a guy is hooking up, you park the tractor "close" to the implement. You can then lift those "snatch blocks" and it will let the ball ends slide rearward another few inches.
They are spring loaded so that once the implement is 'hooked', ya just crawl back on the tractor and back up. The ball ends then will slide into the arms and the pull blocks snap closed.
They really work slick once you get the hang of using 'em. :>)
Have a good one,
Allan
third party image
John Hobby
01-20-2005 03:45:31
 Re: About Allan's 3-point picture in reply to Allan in NE, 01-19-2005 06:31:35
I have a 584 with the sldie arms, best thing ever. When I bought it they were so frozen it took heat, a payloader and backhoe, chains with "D rings and a huge sledge hammer beating the hell out of the sides to bring them apart. Now, oil oil oil oil all the time.
williamf
01-19-2005 07:30:44
Funny how when you know how something works it suddenly makes perfect sense. Wonder how many farmers fought and struggled to hook something up because they didn't know about that feature.
Wm
Allan in NE
01-19-2005 07:39:36
 Re: About Allan's 3-point picture in reply to williamf, 01-19-2005 07:30:44
Aw Heck,
I used chain saws for years and years until someone finally showed me one day that there was a rope ya pulled and the darned things would start makin' noise. :>)
Allan
Allan in NE
01-19-2005 06:36:53
This tractor used to live over in Iowa. I don't think whoever owned it ever used the 3-point; either that or they didn't know how to use 'em.
I spent two full days diggin' the dirt and crap outta these arms. They were fronzen solid and after soaking them in penetrating oil, I had to hook to another tractor to get them to break free.
Allan
Sloroll
01-19-2005 06:47:43
 Re: About Allan's 3-point picture in reply to Allan in NE, 01-19-2005 06:36:53
In Iowa we rarely back a tractor crooked Allen. If the cab is in the way the dog barks when you are in position. Mine will drop the hitch pin too.
Allan in NE
01-19-2005 07:07:58
 Re: About Allan's 3-point picture in reply to Sloroll, 01-19-2005 06:47:43
Aw Ha!
I always thought that darned dog was tryin' to tell me somethin', but I was never smart enough to figure out just what.
I thought he was upset because I was backin' the left rear tire into a loader tooth. :>)
Allan
Sloroll
01-19-2005 06:28:21
I use mine when I don't back the tractor in quite square. Of course that rarely happens.
Harley
01-21-2005 07:17:08
 Re: About Allan's 3-point picture in reply to Sloroll, 01-19-2005 06:28:21
Hey Slo, down here in the Ozarks, we just buy enough M's to have one for each piece of equipment, then we don't have to unhook anything. Later, Harley
