Connecting rod bushings
CNKS
01-19-2005 12:40:38
I do not have a press. Is there a safe way to remove the old rod bushings (piston end) and install new ones without a press or should I take it to someone who has one? Thanks!
El Toro
01-19-2005 14:32:48
 Re: Connecting rod bushings in reply to CNKS, 01-19-2005 12:40:38
Hi CN, Allan's right on those rod bushings. One more thing I think you should consider are the valve springs if this engine has a lot of hours on it. They do get weak from use. Just another thought. Hal
CNKS
01-19-2005 17:26:20
 Re: Connecting rod bushings in reply to El Toro, 01-19-2005 14:32:48
Thanks -- the head is at the machine shop, he will fix anything wrong, including the springs.
Allan in NE
01-19-2005 12:46:53
Hi CN,
I'd take the new pistons, pins and rods to a machine shop. They have to be honed for .001" oil clearence anyway.
Allan
CNKS
01-19-2005 12:56:28
 Re: Connecting rod bushings in reply to Allan in NE, 01-19-2005 12:46:53
That was a fast answer -- you must have been waiting for me. You answered my next question about the clearance also, forgot about that, the shop manual mentions it. The engine kit is coming from the same place as the crank is being ground, so he will do it, thanks.
Allan in NE
01-19-2005 13:06:01
 Re: Connecting rod bushings in reply to CNKS, 01-19-2005 12:56:28
Yes Sir,
I agree; do it right and the thing will easily run another 60 years. They be tough ol' buggers! :>)
Allan
CNKS
01-19-2005 13:14:02
 Re: Connecting rod bushings in reply to Allan in NE, 01-19-2005 13:06:01
There isn't going to be a single original part in the engine except the block, head, rods (unless machinist finds something wrong) and a reground crank. Well perhaps the rockers and push rods, hope they are ok, haven't paid much attention to them yet. My experinence with the rest of the engine indicates they won't be.
