300 utility steering parts
charles tolbert
01-19-2005 15:36:20
where can i find steering parts (or even the entire box) FOR A 300 UTILITY? CAN A STEERING BOX FROM ANOTHER MODEL TRACTOR BE USED?
big fred
01-20-2005 11:22:31
 Re: 300 utility steering parts in reply to charles tolbert, 01-19-2005 15:36:20
The 300U and 350U use the same box, so you can salvage parts from one to use in the other. The 460U box is pretty much a direct bolt-in, but the boxes are different inside, so few if any parts will interchange.
Michael Soldan
01-19-2005 21:05:36
Charles I don't know where you are located but Ontario Used Tractor Parts (519) 523-4922 has those steering boxes and may even have some dismantled so you can get just what you need. Steve will ship anywhere and he will tell you the truth about the condition of the box or parts thereof... a really good guy to deal with.....Mike in Exeter Ontario
TDK
01-19-2005 19:17:35
Boxes for a 300/330/350 will work. Also a 460 utility box will fit. Good Luck !!
Jack Proffitt
01-19-2005 18:26:28
If a 350 utility will work I might know where one is. Jack (KY.)
PAULIH300
01-19-2005 16:20:06
They occasionally show up on EBAY but they are usually manual boxes with slop in them.And still,then,they go for over $200.
I would think the 300/330/350U would all be the same,but one would believe (hope) that IH improved the design in later models.Thus rendering them non interchangeable.
CASE/IH should offer some sort of compensation (thats wishful thinking!)for 300/330/350U owners without P/S toward a new system (of some kind).Its got to be the weakest link in the Utes.
300Randy
01-20-2005 05:38:35
 Re: 300 utility steering parts in reply to PAULIH300, 01-19-2005 16:20:06
The manual steering on my 300U with a front end loader on really gives me a workout when I mow my 6 acre prarie field. When I'm done I feel like Ive been at the gym lifting weights for 3 hours. Can't do that with a new tractor.
harnessbc
01-19-2005 19:29:19
..... .'CASE/IH should offer some sort of compensation'.....
..... .paul, hi..... ..that is a great idea(my 330 isn't even 50 yrs. old yet)..... .as soon as you become aware of the necessary forms needed to submit for our remuneration, please post it on this board..... ...is nothing built to last????? ..... ...best wishes
