966 Open Station Platform
Migraine
01-19-2005 21:26:06
Since I now have the old junk cab and every piece of sheet metal off this minibrute, and every ounce of fluid out and cleaned the transmission housing and flushed twice, would like to start the reassembly process. Got the fenders ready to put on but my trusty ITT manual doesn't show if there was some filler strips that need to go on to "square" off the original platform. I think this was an original open station tractor and later added the house on it but may have had to take off some original plates to get it on. And rather than wonder too long about it, I'll just ask the experts here. Somebody knows something. Migraine
Gordo
01-20-2005 09:47:03
 Re: 966 Open Station Platform in reply to Migraine, 01-19-2005 21:26:06
I wouldn't call them "fillers" as much as upper mounting brackets. I went and looked at my black stripe. There is an upper mounting bracket/plate that the two upper horizontal fender bolts slide into. This plate has two vertical bolts to the platform. It is about two inches wide and 14 inches long.ANd yes it does fill up the space between the platform and the fender though.
Gordo
Allan in NE
01-20-2005 10:24:23
 Re: 966 Open Station Platform in reply to Gordo, 01-20-2005 09:47:03
Hi Gordo,
Yep, that sounds like the gizmos. Should fill up this gap in the rear of the platform?
Allan
third party image
Gordo
01-20-2005 19:42:26
 Re: 966 Open Station Platform in reply to Allan in NE, 01-20-2005 10:24:23
Allan, Tell me how to get a photo off my dig camera onto the board And I will send better photos..Gordo
Migraine
01-20-2005 07:51:39
Looks like I get to go to the salvage yard again. They can see me coming a mile away and get the path to the I.H. pile cleared out. Got to see if there are any seat cushion brackets there as well. Plus a few more items that I'll just have to take home when I see them. I must have enough extra parts around here now to build up a couple relics from the grave!
Allan in NE
01-20-2005 08:15:42
 Re: 966 Open Station Platform in reply to Migraine, 01-20-2005 07:51:39
Yep,
We're havin' more trouble takin' the cabs off than they originally did puttin' the silly things on.
So it goes with old iron, I guess.
Allan
MAGNUM
01-20-2005 07:50:50
yes there are brackets a left and a right, i call them fender extension brackets, i got lucky when i took the cab off my 1466,the brackets were both there,i was told that they are hard to find.
trulyred
01-20-2005 06:03:29
Originally the 66 series fenders were connected to the platform because smaller u-bolts were used along with some rubber grommets and bushings that made the fenders pretty unstable without being connected to the platform.
Allan in NE
01-20-2005 06:12:25
 Re: 966 Open Station Platform in reply to trulyred, 01-20-2005 06:03:29
TR,
Yes, but wasn't there a "filler panel" that went in that "cut out" portion at the rear of the platform? Or does the "boxed bracket" fit in that space?
Seems to me that there was a 2 or 3" filler panel that goes in there and the boxed bracket bolts to it?
We need a picture of the rear of an original platform. Anyone?
Thanks,
Allan
Novel Idea Guy
01-20-2005 07:02:55
 Re: 966 Open Station Platform in reply to Allan in NE, 01-20-2005 06:12:25
Yes, there are supposed to be filler panels in there to bolt the fender to the platform.
