TA Question on 400D
Farmall Frank
01-20-2005 01:16:09
I"ve been busy replacing the TA and removed the clutch and carrier from the TA and kinda goofed up (maybe) when I removed the large nut and toothed washer that holds the clutch carrier on the splined shaft.
My concern is the toothed washer. Does the toothed washer have a indexing tab or tooth on it"s INSIDE edge to index it to the splined shaft? I ask this because when I drove off the large nut, I did not realize that the washer was behind it and kind of bent the toothed washer, and MAY have sheared off this indexing tab, IF there was one. As luck would have it, I put the whole thing back together before I got to thinking about how the heck the nut could be held on without some sort of indexing tab on the inside edge of the washer.
I would appreciate any type of advise on this.
farmalljim10
01-20-2005 03:53:07
 Re: TA Question on 400D in reply to Farmall Frank, 01-20-2005 01:16:09
Yes as I remeber it does,as I remeber it is a small one to about 1/4 inch.
DWV
01-20-2005 03:52:37
Yes tab on ID,tab on outside of washer needs bent into one of notches in nut also.
Farmall Frank
01-20-2005 04:33:23
 Re: TA Question on 400D in reply to DWV, 01-20-2005 03:52:37
Thanks guys. I appreciate it. Atleast I know how to work on this thing now!
Now to get a new washer somewhere (hopefully). If not, I guess loctite blue might work.
Mike S 806/H
01-20-2005 20:38:58
 Re: TA Question on 400D in reply to Farmall Frank, 01-20-2005 04:33:23
You can get them from CaseIH
