350 Diesel water pump
Merle
01-21-2005 11:26:22
Just got a call from my old 350 diesel and it seems the water pump is going out. I suggested Monties in chicago at 312-225-2660. Does any one have any other suggestions for parts for the Continental 193?
El Toro
01-24-2005 08:56:43
 Re: 350 Diesel water pump in reply to Merle , 01-21-2005 11:26:22
They gave this email too. DRDiesel@FoleyEngines.com
and their toll free number is 1-800-223-6539. Hal
El Toro
01-24-2005 08:50:20
Try this email address for a pump. info@foleyEngines.com I have their toll free number if you need it. They claim to have the pumps. Hal
J. Schwiebert
01-22-2005 02:08:44
Where are you located? There is a place in Toledo that was a Continental distributor and one of there sidelines is the rebuilding of obsolete water pumps.
Merle Hoppenworth
01-24-2005 06:36:36
 Re: 350 Diesel water pump in reply to J. Schwiebert, 01-22-2005 02:08:44
I would be interested in more info on the Continental place in Toledo. (name tel #)
Thank You, we are in central Iowa
515-830-0445 7-5
seeing red
01-21-2005 17:02:04
Mine went bad on my 350D as well. I used one from a 430 or 530 Case. I had to use a rat tail file and open the holes just a little bit, but the fit was VERY close.
The Bates Corporation has them but like many other 350D parts, they are pricey.
Tractor Dan
01-21-2005 13:38:48
the water pump went on my 350 diesel so i braught it to the dealer to have it repaired and an inexperienced mechanic threw out all the old parts before he went to order the new then found out that there were many things he couldnt get i ended up going to a friends machine shop and he hand to make new parts
it took quite some time but the dealer finally split the bill i hope you have better luck than me
