Sediment Bowl
PAULIH300
01-22-2005 11:47:27
If you turn off the shut-off lever on the sediment bowl,will this allow the glass bowl to be removed without fuel flowing out? Or does it just shut off the flow to the fuel line (carb)?
Bubba
01-22-2005 11:53:38
 Re: Sediment Bowl in reply to PAULIH300, 01-22-2005 11:47:27
yep! when you remove the bowl, look to see if you have a screen filter. some do and some dont? clean it!!!
scott-mn
01-22-2005 11:49:29
Sure will turn of valve and you can remove sediment jar.
