Order Farmall Cub Parts Online
1954 Cub wiring needs
Candyce
01-22-2005 17:20:02
Have a 1954 Cub with a magneto ignition. Need a wiring diagram for generator, regulator, & starter. Example wiring off amp meter & other connections. Thanks for your help!
Dave (IL)
01-22-2005 23:11:13
 Re: 1954 Cub wiring needs in reply to Candyce, 01-22-2005 17:20:02
Don't know Cubs specifically, but, in general, a magneto don't give a hoot about the electrical system. It's not connected at all.
Only thing I can think of that might cause a Farmall confusion is that the little round push/pull switch that an H has is open when pulled out for mags and closed when pulled out for battery ignition. On a mag H the wire runs up to the grounding terminal on the mag. Push button in, switch turns on, grounds the points in the mag to kill it.
On a battery ignition H, that button has batt on one side and a wire to the coil on the other. When you pull it out it turns on and puts voltage on the coil.
At least that's what I think.
Candyce
01-22-2005 19:26:52
 Re: OOPS!!! 1954 Cub wiring needs in reply to Candyce, 01-22-2005 17:20:02
The informaion given is for battery ignition... I need a wiring diagram for a magneto ignition... 6 volt electrical system... Help appreciated!!!
Jim Becker
01-22-2005 17:54:32
Look at page 2 of the ATIS Cub FAQ, question 3. Starting in '50, virtually all Cubs came with battery ignition.
Candyce
01-22-2005 18:43:35
 Re: 1954 Cub wiring needs in reply to Jim Becker, 01-22-2005 17:54:32
Thank you for the GREAT information! Appreciate it!
