Super C, 200, 230 remote hydr?
Mark R. in NY
01-22-2005 18:46:46
Anyone ever seen remote hydraulic line on a 200 or 230? Or know if you could plumb one in? I have a 2 bottom IH hydr trailer plow (14") and it seems this would be the right tractor to pull it with. Thankyou!
MN Scott
01-23-2005 13:34:11
 Re: Super C, 200, 230 remote hydr? in reply to Mark R. in NY, 01-22-2005 18:46:46
Here is the valve and lines you need to add rear outlets on your tractor. All you would have to do is obtain the hoses and couplers for the rear hookup.
CNKS
01-23-2005 08:37:07
If you can't find the factory system, www.saginawcountytractor.com sells a conversion block that fits between the hyd lines and the reservoir on your touch control, along with a spool valve that mounts on the light bar (you can buy spool valves anywhere). These are for their 3-point hitches. Not as neat an installtion as factory, but works ok. It does not interfere with normal operation of the rockshaft.
CNKS
01-23-2005 08:39:38
 Re: Super C, 200, 230 remote hydr? in reply to CNKS, 01-23-2005 08:37:07
Also, their website will not list this item, you will have to call the number listed on the website.
kopeck
01-23-2005 06:52:10
My grandfather's 200 had remotes that were factory. He used to have to do something to redirect the fluid from the loader if memory servs.
He used to run a corn chopper on it...
K
Mike@NY
01-23-2005 06:24:06
My Neighbor up the street has a 230 with fast hitch and a remote hookup, all factory. Nice little tractor. I had an oppurtunity to buy it from the previous owner, but passed it up. Kinda kicking myself for it now. In the parts book for my C, I see a listing for a remote hookup. One should be able to add on aftermarket system for a remote, another friend's mother's Super A has one put on for a loader that is on it. Others can probably give better details on how to actually do it. Yes, that does sound like a good size plow for this size tractor. Good luck!
Mike@NY
