Transmission Lubricant
PAULIH300
01-22-2005 19:40:07
In my 300U operators manual,it says to use 10W motor oil for the transmission,and to add Torque Amplifier additive if it has TA.What was this additive? I cant imagine what that would be for.I thought the TA was all gears (planetary) and wouldnt need any friction modifier (unless it was for the ramp/roller deal).
Is there any other type of TA to replace the original IH unit? Something more durable?
CNKS
01-23-2005 19:53:35
 Re: Transmission Lubricant in reply to PAULIH300, 01-22-2005 19:40:07
Your manual was printed before Hytran came out -- just use hytran.
ejr
01-23-2005 10:17:54
We took the ramp and rollers out and machined in a sprauge out of a 1066 ta.
Nebraska Cowman
01-23-2005 04:51:37
third party image
I think this is the aditive but no one uses it anymore. We buy Hy-trans from IH
TDK
01-22-2005 20:48:56
Use IH Hy-Tran instead of the 10W with additive. Hi-Capacity, maybe others, sell a heavy duty T/A. Unless you're pullin' or very abusive to the T/A, the regular version should be good enough.
Bernard Reunking
01-28-2005 14:33:55
 Re: Transmission Lubricant in reply to TDK, 01-22-2005 20:48:56
Hi thran is the only oil to be used in I H tractors with a ta. Because Hy thran Will pick up the water and hold it in suspendtion in the oil. If the fluid is milkie or by losinng the bottom drain plug and water drips out you waited to long to drain and put new hy Tran in. Water will set on the T A and rust and T A will fail. I was told this 24 years ago by a shop boss. I have one SUPER M TA for 24 years. Changed fluid every other year and never replaced the TA. Grain farmer and use it almost every day. The pto is independent and holds two qts. and should be changed also. Even if it is not used.
