2 POINT LIFT
GO GO
01-23-2005 17:55:32
WHAT IS THE GOING PRICE FOR A 2POINT LIFT TO FIT A FARMALL SUPER C AND WILL IT BE HARD TO FIND
Hayshaker5
01-24-2005 04:07:58
 Re: 2 POINT LIFT in reply to GO GO, 01-23-2005 17:55:32
If you can find a fast hitch system, that would be a lot better in that the fast hitch is designed to fit your tractor better than most 3 point aftermarket kits, plus with the capability to use both fast hitch equipment or with adaptors to use 3 point equipment. I have found a few fast hitch pieces of equipment very reasonably, such as an 8' blade, post hole digger, 4 bottom plow, a 4 row cultivator, plus other fast hitch points to make my own equipment. If i had a choice between the two systems I'd take the fast hitch for the ease of hitching and unhitching.
kjm
01-23-2005 21:09:00
While I like the fast hitch if I was buying one, it would be an ad on 3-point.
Novel Idea Guy
01-23-2005 19:35:33
They are extremely hard to find, and they will be worth whatever the seller is asking. If you haven't figured it out already, it's a seller's market on rare parts.
