How can I hop up the 122.7 in my 240U?
Red Rookie
01-23-2005 18:32:33
I would like more power in my 240. I want to do a valve job anyway. What should I do while I'm in there? Will porting the head and matching it to the manifold help much? What about milling some off the head? If so, how much? Any other tips? Can bigger pistons be installed?
Steve from MO - dangit!
01-24-2005 13:14:48
 Replace it. in reply to Red Rookie, 01-23-2005 18:32:33
Unless you are stuck on original parts, you might be able to put in a 153 cid combine engine.
K.B.-826
01-23-2005 19:05:51
 Re: How can I hop up the 122.7 in my 240U? in reply to Red Rookie, 01-23-2005 18:32:33
A carb and governor from a 504 would be a good start. Electronic ignition will be good for 1 or 2 extra horsepower. I'm not 100% sure, but I think you can drop in C-135 sleeves and pistons, just make sure the outside diameter of the C-135 sleeves are the same as yours.
