Need iformation on farmall 504 hydraulics
4 States Salvag
01-23-2005 19:13:56
Hello,I recently got a narrow front farmall 504 with p/s T/A and auxilliary hydraulics along with the 3 pt lift.Does anyboby know where I check the hydraulic fluid level and where do you fill it.Does it have a filter on the hydraulics and if so where in the world is it?Is it under the seat?? I am lost.The lift only comes up a little and I believe it is low on fluid.
Dale
Sloroll
01-24-2005 09:52:21
 Re: Need iformation on farmall 504 hydraulics in reply to 4 States Salvage, 01-23-2005 19:13:56
To the front about a foot and down about 6" from the clutch pedal there is a cap plug with a smaller screw in it..7/8"?? plug with a#8 screw drilled to the center. That is your hydro full mark.
Wardner
01-24-2005 06:41:18
The transaxle fluid (Hy-Tran or equivalent) is the hydraulic fluid. The capacity is around 10 gallons.
The filter is located behind a 4" x 6" flat plate on the right side of transaxle. I think there are six bolts that hold it on.
I suggest that you get a manual.
kjm
01-23-2005 21:05:44
4-SS, I think there is a check plug on the left side under the step,but threr are too many IH to keep them all straight! kjm
