300 utility
gpranch
01-24-2005 17:36:28
I am in the process of converting my 1956 utility
to 12 volts and would like to know the resistor to us for the 6 volt lights
captaink
01-25-2005 07:17:47
 Re: 300 utility in reply to gpranch, 01-24-2005 17:36:28
You will get better light with 12 volts, so I recommend you change the bulbs or put on new halogen lights.
TDK
01-24-2005 19:28:04
Changing the bulbs is the best way to go, as long as you don"t mind paying 60 - 70 dollars a pair for the origonal type sealed beams. You can buy sealed beams from any auto parts store but they won"t be like the origonals. They will have to be "rigged" to hook up the wires. At 5 - 6 dollars, I"d at least try the resistor. You"ll have to have a resistor on power lead to coil, so just get one with 4 plugs(2 circuits) such as NAPA/Echlin # ICR 24. Much depends on purpose of your tractor -show or actual use. Maybe someone else will have a better idea. Good Luck!!
PAULIH300
01-24-2005 17:46:44
Convert everything over to 12V,you'll be glad you did.Bring it into the 20th century (anyway),and you will find that replacement parts are more available and cheaper too! (bulbs,coil...etc).
Irv
01-24-2005 17:42:09
Why bother - just put in 12 bulbs. Irv
CNKS
01-24-2005 17:41:46
Change the bulbs.
