H fuel tank replacement needed
Jon from SD
01-25-2005 14:38:17
Hi,
My H's tank is corroded around the outlet at the bottom - where is the best place to obtain a new tank?
I searched the archives on this forum, but didn't turn up much - just some ways to fix pin holes and such.
Thanks,
Jon
Novel Idea Guy
01-26-2005 09:00:26
 Re: H fuel tank replacement needed in reply to Jon from SD, 01-25-2005 14:38:17
Here are some novel ideas: Try a tractor scrapyard. Search for "used tractor parts" both here and on Google. Check your local yellow pages. Make a few phone calls.
Gordo
01-26-2005 07:44:38
 O/T H fuel tank replacement needed in reply to Jon from SD, 01-25-2005 14:38:17
If you need original fenders I have a pair here in Mitchell SD.Hand sanded, primed, not a spot of rust , zero dents, no filler.
Gordo
chad mn
01-25-2005 21:26:37
i have a good used tank also. ranger@smig.net
Nebraska Cowman
01-25-2005 16:31:32
jon, I've got good used tanks. my email is always open.
farmalljim10
01-25-2005 16:10:38
If the tank has no holes they make a substance to reline the inside and protect the inside of it .I cant remeber the name of it I think it is called gas tank reliner..Check around I think it will work...
RustyFarmall
01-25-2005 14:56:14
To my knowledge there is no one making new tanks. You will have to find a good used tank, and yes, there are some very good used tanks available. Place an ad in the classifieds section of this site, I am sure you will get several replys.
