Looking for a blow up of a starter
MagMan
01-25-2005 18:12:37
Hi guys, Does anyone know where I can find a scematic of the inside of a delco tractor starter. I took the starter off the cub and there is a 1/4" end play in the shaft between the two end bushings. And I beleve thats what wore the drive out it was not able to go in all the way and ground the ends off the drive gear. I need to see a blown up pic so I know where washers and such go. Or maybe I Can see whats wrong. THANKS JON
Bob
01-26-2005 06:06:28
 Re: Looking for a blow up of a starter in reply to MagMan, 01-25-2005 18:12:37
The manual is on the Cub Collector's site:
Here's the starter pages:
Link
Link
MagMan
01-26-2005 07:42:08
 Re: Looking for a blow up of a starter in reply to Bob, 01-26-2005 06:06:28
Thanks BOB, Thats what I have in my starter but I also have that end play I will have to try a few different things now. JON
Bob
01-26-2005 08:44:52
 Re: Looking for a blow up of a starter in reply to MagMan, 01-26-2005 07:42:08
Do you have the thick leather washer installed next to the commutator?
MagMan
01-26-2005 11:24:07
 Re: Looking for a blow up of a starter in reply to Bob, 01-26-2005 08:44:52
No There is a small beveled one thatkeeps it tight in the bushing. Most starters have one but I think its usally at the drive end but the shaft is smaller at the comulator end so its in the right spot. Then a washer at the other end . It is the same as the cub manual. Maybe the starter drive that was in this was not installed crectly or something. The new one will be here with UPS today just waiting to see if anything jumps out at me when it gets here. JON
brtx
01-26-2005 03:48:31
jon..i can send you a fax copy of my 460 parts book. someone on here should have a link to delco starters.if you need the fax holler
GeorgeH
01-26-2005 02:30:10
Page 58 and 60 of my H parts book has starter breakdowns. Can send you one of those pages by e-mail if you don't have.
brtx
01-26-2005 02:25:43
jon...in the brush end of the starter there is a thrust washer that fits between the armature and the end plate. that is what cotrols the end play in the starter.hope this helps.
MagMan
01-26-2005 05:03:11
 Re: Looking for a blow up of a starter in reply to brtx, 01-26-2005 02:25:43
It has a beveled type that looks like it centers it at the brush end. I beleve most starters have this. Then it has a washer at the other end by the drive. Do you think someone forgot one at the armiture end . JON
