lugs
watsline
01-25-2005 21:49:25
where can I find the lugs to fit a M farmall for the front wheels?
Nebraska Cowman
01-26-2005 06:09:57
 Re: lugs in reply to watsline, 01-25-2005 21:49:25
I might have a few but doubt if I can find a full set.
Andy Martin
01-26-2005 05:39:26
Might want to ask your question again.
If you mean lug bolts, to hold the steel rim to the cast wheel, standard M rims bolt to the wheels with square head bolts. Machine screws work OK.
If you have smooth rims and late model wheels and need the lugs which rivet to the rim and bolt to the wheel, look for good used rims with th e lugs already on.
If you have steel wheels, the front wheels don't have lugs.
watsline
01-26-2005 05:55:42
 clamps in reply to Andy Martin, 01-26-2005 05:39:26
Andy, I stand corrected. i should have front wheel clamps, thanks.
Andy Martin
01-26-2005 12:06:48
 Re: clamps in reply to watsline, 01-26-2005 05:55:42
I was not trying to be smart, just did not understand.
I'd like some clamps too, have lots of worn out ones. Try the salvage yards.
