WIDE FRONT SWAP FOR MY 400
BULLDOG
01-26-2005 09:40:17
I HAVE A TRICYCLE 400D. I ALSO HAVE A WIDE FRONT OFF A 460 (I BELIEVE). I HAVE THE PROPER BOLSTER ETC TO MOUNT IT TO MY 400 BUT I WANT TO USE MY ORIGINAL CAST OPEN CENTER HUBS INSTEAD OF THE 460 STYLE. THE PROBLEM IS THE SHAFT WHERE THE INNER BEARING RESIDES IS LARGER ON THE WIDE FRONT THAN ON THE TRICYCLE. OTHERWISE THE SHAFT IS THE SAME LENGTH ETC. HAVE ANY OF YOU MADE THIS SWAP? DOES ANYONE KNOW THE BEARING NUMBER I WILL NEED? THANKS IN ADVANCE!
DEWAYNE
captaink
01-26-2005 10:42:38
 Re: WIDE FRONT SWAP FOR MY 400 in reply to BULLDOG, 01-26-2005 09:40:17
If no one else here gives a bearing number, you can take both inside bearings to a part house or a bearing house and they will be able to use the inside race inside diameter of one bearing and the outside diameter of the outside race and look to see if there is a bearing made that will work. If you have a micrometer, you can measure the shaft and the outside race outside diameter and get the same info and check with bearing suppliers to find out if there is a bearing that will work.
