diesel engines for farmall super a
norman cochrane
01-27-2005 10:34:59
i have a farmall super a the engine is toast .does anyone know if i can shange it to diesel and if so what kind any info would be greatly appreciaced
thanks norm
Jack in OH
01-28-2005 11:28:16
 Re: diesel engines for farmall super a in reply to norman cochrane, 01-27-2005 10:34:59
Norm, boy did you get them going with that diesel question. Good thing you didn't tell them you were going to paint it green when you were done!
I always like to see things at tractor shows that show how innovative people can be . I think a diesel Super A would be interesting, and I own a Super A.
Original is not the only way to live.
BigDiesel
01-27-2005 16:34:30
a couple of years ago ,i has a D166 diesel power unit on a pump. It was a IH engine similar to a 340 engine, but the bellhousing was the same as a C123 used on a Super A or C. i sold the engine, but i thought it would have been neat to put it in a Super C tractor. Find one of those and a Super A diesel is possible.
Hugh MacKay
01-29-2005 04:28:21
 Re: diesel engines for farmall super a in reply to BigDiesel, 01-27-2005 16:34:30
Big Diesel: While I agree it will bolt up, you would need a Super A flywheel, then SA ring gear, will it stand torque of cranking the diesel? Then there is the problem of the 3 bolt starter from the 340. Best buy up a dozen SA torque tubes. It may indeed be possible to overcome these obstaciles.
Hugh MacKay
01-27-2005 14:49:48
As an old farmaer back home used to say this forum has gone from worse to worser. Dont be so ridiculous.
Paul in Mich
01-28-2005 18:03:35
 Re: diesel engines for farmall super a in reply to Hugh MacKay, 01-27-2005 14:49:48
Hugh, Shucks, are you trying to infer that it is pure folly on my part to consider building that SuperB-N-T-A-D-V?
Paul in Mich
01-28-2005 18:05:20
 Re: diesel engines for farmall super a in reply to Paul in Mich, 01-28-2005 18:03:35
Oops, Hugh, I mean "imply".
Hugh MacKay again
01-29-2005 04:20:30
 Re: diesel engines for farmall super a in reply to Paul in Mich, 01-28-2005 18:05:20
Paul: Whether you infer or imply, I've now been up since 4:58 am EST. Only see one other partaker of the great eastern drink on deck, as of 7:10 am EST. Super B, Torque Amplifier, Diesel, High Crop, one problem I haven't worked out in my sleep, " length of narrow front, I guess one could install a single front wheel from an MV."
Hugh MacKay
01-28-2005 19:27:11
Paul: Wont comment tonight, our daughter and son in law arrived from Halifax. Of course in good old Maritime tradition, some east coast black rum accompanied the trek across country. Tractor page is off limits except to acknowledge I'm here.
ejr-IA.
01-27-2005 12:31:37
Have seen a small Deutz in a H.
lee
01-27-2005 11:53:10
You can get to 3.250 overbore for increased power with the right block with 3.436 lower sleeve diameter. The overbore kits can make significantly
more power.
26Red
01-27-2005 11:26:26
How about a 3 cylinder diesel? Don't know what brands there are- but you might get hassled if you stuff a non- American engine in it... You would have to make a external frame because the A's engine is part of the support structure of the tractor.
I would rebuild the existing engine or find a Super A or Super C engine (same size?) to put in it.
Andy Martin
01-27-2005 10:53:27
In that the engine is part of the frame, it would be surprising if you could find an engine without adding an external frame.
The little engine can't be all that bad.
Super A
01-27-2005 12:11:49
 Re: diesel engines for farmall super a in reply to Andy Martin, 01-27-2005 10:53:27
I agree. Don't butcher such a fine tractor. Everything for a full rebuild is available at reasonable costs, and last I knew some outfits still offered complete shortblocks. I suspect by the time you transplanted a diesel, you would have way, way, way more than the tractor's worth, and no one would want it if you ever decided to sell it.
my $.02
Al
Dente
01-27-2005 17:29:27
 Re: diesel engines for farmall super a in reply to Super A, 01-27-2005 12:11:49
Al , would you happen to know who still supplys those short blocks and what the cost might be around. Would appreciate any info
John *.?-!.* cub owner
01-29-2005 09:06:56
 Re: diesel engines for farmall super a in reply to Dente, 01-27-2005 17:29:27
Dente, unless your block casting is severley damaged, those are wet sleeve enigines and not all that difficult to rebuild.
Don Voit
01-28-2005 18:03:05
Where are you?? I can rebuild your a engine
