Need head bolt torque for Farmall 560 LP
Farmall560LP
01-27-2005 11:50:14
I am reinstalling the head on my Farmall 560 LP after a valve job and sorely need the torque specifications before I start. Any assistance appreciated.
ejr-IA.
01-27-2005 12:49:01
 Re: Need head bolt torque for Farmall 560 LP in reply to Farmall560LP, 01-27-2005 11:50:14
That would be 85-95 foot lbs.Valve setting .027 warm all valves.TDC set 123579 on no.one piston.No.6 piston tdc set 468101112.
Farmall560LP
01-27-2005 13:51:31
 Re: Need head bolt torque for Farmall 560 LP in reply to ejr-IA., 01-27-2005 12:49:01
Many thanks for the information. I follow you on the torque and the valve clearance, but do not understand setting the top dead centers for cylinders one and six as I have not moved the distributor or turned the engine since removing the head. Can you explain?
Andy Martin
01-27-2005 14:48:13
 Re: Need head bolt torque for Farmall 560 LP in reply to Farmall560LP, 01-27-2005 13:51:31
With No. 1 at TDC, he listed the valves which could be adjusted. Then the rest at No. 6 TDC.
Farmall560LP
01-28-2005 09:39:41
 Re: Need head bolt torque for Farmall 560 LP in reply to Andy Martin, 01-27-2005 14:48:13
Thanks Andy. I had just about decided this was what he had meant but it threw me as I had not expected such detailed information on adjusting the valves. It is great information though and very much appreciated. Ron
