Info on 706 Inter
Mike Horgan
01-27-2005 20:15:22
May be able to buy a 706 Inter. Would be grateful for opinions on this model. I would pull a round baler with it. Are they reliable, what is the hydraulic flow rate. Where is the Hyd pump mounted, is it easy to get at. What is the PTO horse power. Are they wet sleeve motors. The cab looks very good with air con . Are there things I'd need to watch out for. Are they a convenional straight gear box ? any opinions gratefully sought regards Mike.
JJK
01-29-2005 16:05:21
 Re: Info on 706 Inter in reply to Mike Horgan, 01-27-2005 20:15:22
About the hyd pumps, the MCV pump is located on the left side of the speed trans behind the bellhousing controling the steering (which has priority), brakes, and the torque. The hitch pump is located on the left side of the range trans in front of the axle housing controlling the hitch and auxillary remotes. The pto pump is right on the pto itself and operates the pto only. The MCV pump and hitch pump both pull oil through the filter housing on the right side of the range trans and the pto pump just has a screen in the suction tube if this means anything more to you.
Chadd
01-28-2005 09:05:11
The 706 is simply the "smaller brother" of the 806. That means that it has a hi/lo range 4 speed. It is equipped with a mechanical park brake, and can be either diesel or gas. There were two options for the diesel engine and a gas engine. Someone check me if I am wrong but the diesel engine could be the D-282 or the D-310 depending on the year. The 282 is an American-built 6 cyl. diesel with glow plugs. It is the same engine as in the 560 and 660 and has the injection pump located on the right hand side of the tractor when sitting on the seat. The 310 is a neuss build 6 cyl. german diesel. It uses direct injection and has its injection pump on the left hand side of the tractor when sitting on the seat. The gas engine is 263 or a C-291, both six cylinders and I believe, are good motors, however, they burn a lot of gas and have had durability problems for certain people. I would still recommend the gas engine, just less than the two diesels. The tractor has 3 hydraulic pumps. 1 in the clutch housing powering the steering, brakes,and torque-amplifier(if equipped), 1 in the rear end to power the 3 or 2 point hitch(if equipped) and I think the pto and another to power the remotes at the back. Options included torque-amplifier which uses a planetary gearset to give 16 forward speeds and 8 reverse speeds. Since this tractor's is hydraulic, it will hold back on hills, which is a big advantage over the older ta equipped ih tractors. Also, fender mounted headlights, a high output hydraulic pump for the remotes (indicated by a an s or a y at the end of the serial #. I believe that the 282 is a wet sleeve engine but I don't know what the 310 is. The horsepower(PTO/drawbar) for a 263 gas equipped 706 is 74/66. The 291 is 76/68. The 282 is 72/67. The 310 is 76/69. The hydraulic flow rates I don't know off the top of my head, and I would have to look them up. As for things to look out for, make sure the owner changed the engine AND the transmission oils and filters regularly. Not doing these things leads to premature death of the pumps and the valves. If there is no power steering after the tractor is sitting for a while, the filter has not been changed and is full, causing the bypass valve to kick in. The fluid should be clean and should not smell burnt. The power steering should turn quickly and not slip over excessively or else the pump is getting weak. 7 revolutions of steering wheel slip is about all that you want to see when the steering wheel is held to the stop. Any more and something is damaged. Lastly, make sure that the TA and the clutch have been properly adjusted. Don't try to adjust them like an old farmall. They are not the same. Talk to a dealer about how to adjust them, because frying a TA is BAD news. Well, I think that answers just about all of your questions. Good luck, they are great tractors, last forever and are fun to use.
Mike Horgan
01-28-2005 22:24:52
 Re: Info on 706 Inter in reply to Chadd, 01-28-2005 09:05:11
Thanks Scott, Allan and Chadd, especially Chadd for the comprehensive reply. The info is great I think I will have a serious look at the 706!. Regards Mike Horgan. Victoria Australia.
MN Scott
01-28-2005 16:34:03
One more correction. The 282D is a dry sleeve engine and the 310D german is the wet sleeve one. Both gassers are also dry sleeve.
Allan in NE
01-28-2005 09:20:53
Hi Chadd,
Boy!, that was quite a run down!
The larger chassis tractors, which are gear drive, have the three pumps yes; but the remotes and hitch both run off the rear belly pump. The PTO has it's own pump.
Allan
chadd
01-28-2005 12:00:19
 Re: Info on 706 Inter in reply to Allan in NE, 01-28-2005 09:20:53
Yep, I just figured I would try to answer everything he asked. I guess it got a little long! Since we have an 806, most of it is the same. I never can keep the pumps on those tractors straight! Thanks for straightening my answer out.
Allan in NE
01-28-2005 12:06:45
 Re: Info on 706 Inter in reply to chadd, 01-28-2005 12:00:19
Chadd,
Yeah, then you switch to the small chassis tractors and the pump assignments change! Hang a hydro in the mix and we add yet another pump.
Geeze, gives me a headache. :>)
Allan
chadd
01-28-2005 12:16:51
 Re: Info on 706 Inter in reply to Allan in NE, 01-28-2005 12:06:45
Well, you know that they can never make anything the same. Everything needs to be different. Even if it is just to confuse the people who work on them!
Novel Idea Guy
01-28-2005 05:42:09
Most of that information is available on the 'web if you put your mind to it and search for it.
Basically, an International 706 is a "Wheatland" version of the Farmall 706. HP ratings, and the basic systems are the same. It's rated in the 70-75HP range.
The hydraulic pump is in the transmission somewhere. Whether it's easy to get to or not, I dunno.
