What were the uses of remote hyd. cyl on SA other
scott#2
01-28-2005 17:16:20
What all could you do with that thing? Just curious if I can some how use it for a wheeled disk or some other use to make life easier.
scott#2
Hugh MacKay
01-29-2005 07:02:43
 Re: What were the uses of remote hyd. cyl on SA o in reply to scott#2, 01-28-2005 17:16:20
scott: You can probably activate most any working, double acting hydraulic cylinder on earth today, that only requires roughly 1,000 psi. You will find it quite slow once you get over a 4" bore cylinder, as that little tractor only pumps about 4.5 to 5 gpm.
CNKS
01-28-2005 18:14:30
Any trailing implement or rear mounted implement that has a cylinder. As to rear mounted implements, the cylinder will lift more than a rear mounted implement attached to the rockshaft.
