400 HYDROLICS
JOSSETTE
01-28-2005 18:52:53
FARMALL 400 BUCKET IS SLOW AND LACKS POWER. DRAINED THE FLUID AND BLED CYLINDERS AND STILL THE SAME. WHEN IT GETS TO 45 DEGREES IT WORKS FINE BUT STILL LACKS HEAVY LOAD LIFTING.
panningbros
01-29-2005 12:22:36
 Re: 400 HYDROLICS in reply to JOSSETTE, 01-28-2005 18:52:53
Is yours gas or diesel? Pumps are different. I have new pump for $550.00 & used for $275.00. Would have to check if we have a used one for sure. Dave
JJK
01-29-2005 10:06:14
Do some more checking before you put in a new pump. Have somebody with a flow meter check out the system to see if it would be the pump for sure or if the problem might be with the regulator valve or something. Easier to find the problem first than to just throw parts at it and still have the same trouble. Good luck!
Novel Idea Guy
01-28-2005 20:11:58
Did you clean the strainer screen?
Your hydraulic pump is probably shot.
Also, it's HYDRAULIC. Why do people have so much trouble spelling it?
JOSSETTE
01-28-2005 20:19:41
 Re: 400 HYDROLICS in reply to Novel Idea Guy, 01-28-2005 20:11:58
BOTH THE STAINER AND THE TANK FILTERS ARE NEW.
WHERE CAN GET A PUMP THAT ISNT $700??
T.B.W.
01-29-2005 11:59:08
 Re: 400 HYDROLICS in reply to JOSSETTE, 01-28-2005 20:19:41
Try Steelwheelranch.com. Got a used pump form them for under 300 with a 30 warrenty
