IH 300 utility ??????
Jayson
01-29-2005 12:42:49
I have recently bought a international tractor. I bought it to be a 300 utility, but it has no emblems on the tractor. It has fresh red paint over all the tractor and the grill is white. How can I tell if it is a 300 or 350?
Thanks Jayson
Ida Red
01-30-2005 20:44:02
 Re: IH 300 utility ?????? in reply to Jayson, 01-29-2005 12:42:49
Have a good IHC front-end loader to fit your tractor.Red
TDK
01-29-2005 14:47:58
Serial # tag on the right side of clutch housing will say I-300 or I-350. The engine will have C-169 or C-175 cast into it on the right side, just above the distributer. Engine ser.# is in this general location also, stamped in a flat pad.There's casting codes on most of the castings which will tell you the month,day & year of each part. Casting code example- 2-20-A = Feb. 20, 1955 (A=55 B=56 C=57 D=58).Can't determin by steering wheel, could have been changed to 350 style. I've seen 350's with both types of fast-hitches supposedly from factory, so this is not a reliable way to determine which tractor you have either. Record the serial numbers on chassis & engine. Let us know what they are and someone here will be able to tell you what you have.
Darald
01-29-2005 14:07:58
I have one of each, the fast way to tell the difference is the steering wheel. 300U has a steel spoked wheel.
350W has a plastic spoked wheel. At least mine are like this.
PAULIH300
01-29-2005 15:04:47
 Re: IH 300 utility ?????? in reply to Darald, 01-29-2005 14:07:58
Yup,I forgot about that one,however 300Us with power steering got the plastic wheel with center emblem.
TDK
01-29-2005 19:50:01
 Re: IH 300 utility ?????? in reply to PAULIH300, 01-29-2005 15:04:47
No, the 300U's with P/S had a plate attached by the steering wheel nut saying "power steering". We had one with P/S but no plate though,so this may have not been used by IH consistently. 350's and up had the fully covered plastic wheels with a center button.
PAULIH300
01-29-2005 13:27:11
Does it have the fast hitch? The 350s had the weight transfer hitch I believe.
What does the Serial Tag say?
