179 engine swap
Elton Fancher
01-29-2005 18:51:44
I need an engine that would replace a 179 diesel. Does anyone know if anything else will bolt up and work?
jb2
01-29-2005 19:57:08
 Re: 179 engine swap in reply to Elton Fancher, 01-29-2005 18:51:44
Hi, is this 179 a 3 cylinder German Diesel engine in a 454,484,495?
Possibly could put a 206 or a 239 4 cylinder German Diesel as a replacement. These engines are used in the 574,584,624,684,695. I know the connection at the torque tube is the same.
Good luck
JB2
K.B.-826
01-29-2005 19:48:04
I doubt it, at least not without changing a bunch of other parts. There is a smaller 3-cylinder German diesel, a 153, I think. I don't know what used that engine. The 179 is fairly common, you should be able to find another one. What tractor is this in?
Elton
01-30-2005 06:21:21
 Re: 179 engine swap in reply to K.B.-826, 01-29-2005 19:48:04
This is in a 3500 backhoe. He wants to use it to load machinery, so a gas engine would be ok.
K.B.-826
01-30-2005 18:57:01
 Re: 179 engine swap in reply to Elton, 01-30-2005 06:21:21
Look into the smaller three-cylinder diesel British utility tractors, like the 484. You might need to buy an entire parts tractor to get all the parts you need.
