engine question
petey
01-30-2005 04:10:02
Hi, what is the difference between the late model M engine and the early model. I am restoring one that has a early model serial number 258xxx but the machine shop where i took the crank says it measures to be the late model crank. Are the pistons different to? What can i do to figure out what overhaul kit i need? Thanks for your help
El Toro
01-30-2005 05:50:33
 Re: engine question in reply to petey, 01-30-2005 04:10:02
The early Farmall M's crankshaft diameter were 2.7475-2.7485" up to SN 278049. The later M's
shaft measured 2.8075-2.8085" starting with SN 278050. The cylinder bore was the same 3-7/8".
The rod journals for SN 278049 were 2.4975-2.4985" and from SN 278050 and up they measured 2.5475-2.5485". Try weberstractorworks.com for your sleeve and piston kit. Hal
Nebraska Cowman
01-30-2005 12:52:50
 Re: engine question in reply to El Toro, 01-30-2005 05:50:33
the more I learn the dumber i get. thanks hal.
El Toro
01-30-2005 13:04:31
 Re: engine question in reply to Nebraska Cowman, 01-30-2005 12:52:50
I feel that way too at times. Hal
Nebraska Cowman
01-30-2005 04:17:46
258,000 is a late model built in 1951
