farmall H serial numbers
rollnwelda
01-30-2005 07:31:33
I just bought a couple of farmalls and both tractors have the prefix FBH on th serial numbers:
Does anybody know what this means or where i might find the answer
CNKS
01-30-2005 08:59:50
 Re: farmall H serial numbers in reply to rollnwelda, 01-30-2005 07:31:33
FAA, A; FAB, B; FC, C; FBH, H; FBK, M, etc. Just IH's model designation system for the letter series.
BRIAN GIBSON
01-30-2005 15:26:22
 Re: farmall H serial numbers in reply to CNKS, 01-30-2005 08:59:50
SER# 8024-D
CNKS
01-30-2005 18:00:33
 Re: farmall H serial numbers in reply to BRIAN GIBSON, 01-30-2005 15:26:22
1939, the 7524th made, the D means 5000 ft altitude pistons.
sammy the RED
01-31-2005 22:02:40
 Re: farmall H serial numbers in reply to CNKS, 01-30-2005 18:00:33
CNKS, Please check your book again.
Me thinks this #8024-D is a part number.
It should have a "X" after the serial number such as: 8024X1B = your answer.
CNKS
02-01-2005 09:29:18
 Re: farmall H serial numbers in reply to sammy the RED, 01-31-2005 22:02:40
You are correct, but IH often did not use the X notation for non-gas engines -- so the D could mean 5000 foot pistons, but you are right, it could be a part number, except that in a previous post he was asking about serial prefixes, so I assumed that except for the "-", that it was a serial number, perhaps not.
WRONG-CNKS
02-01-2005 09:34:00
 Re: farmall H serial numbers in reply to CNKS, 02-01-2005 09:29:18
Me not you, Sammy, if it is an H, 8024 (various suffixes) is the part number of the clutch housing.
sammy the RED
02-01-2005 11:34:34
 Re: farmall H serial numbers in reply to WRONG-CNKS, 02-01-2005 09:34:00
;o]
farmaljim
01-30-2005 08:10:52
That prefix means it is a farmall H with the serial #s you can tell the year.
