Super C oil pressure
Glen E.
01-30-2005 12:35:36
I have a "51 Super C that runs great except for the oil pressure drops when it warms up. Someone said that I might be able to take the bottom off the pump and sand a little off of it. Has anyone else done this, and how do you go about doing it?
Andy Martin
01-30-2005 14:50:07
 Re: Super C oil pressure in reply to Glen E., 01-30-2005 12:35:36
You might do what I do and put 20w50 oil in it. You'll get closer to the cold pressure with the 50 weight and start easier with the 20 weight.
El Toro
01-30-2005 13:12:17
As Justin has suggested on checking those bearing
clearance's, they determine your oil pressure too.
Another place that is sometimes overlooked are the worn cam bearings. Hal
justin w
01-30-2005 13:27:28
 Re: Super C oil pressure in reply to El Toro, 01-30-2005 13:12:17
C113 & 123 engines do not have cam bearings. The cam runs on the block..
El Toro
01-30-2005 14:28:23
 Re: Super C oil pressure in reply to justin w, 01-30-2005 13:27:28
That's really a problem if those cam bores are worn. Wolverine Blue Racer in MI can buildup those cams. Hal
El Toro
01-30-2005 13:11:45
gene b
01-30-2005 13:06:25
You can get new ones for around 60bucks from dealer.
justin w
01-30-2005 12:43:03
The oil pump bottom plate is aluminum, and does have a tendency to warp. I would suggest checking the plate for warpage. If it is slightly warped, it can be resurfaced, but if the plate has warped alot, you will need to buy a new plate. Also, with the oil pan already removed, it would be a smart idea to check the oil clearance of your rod & main bearings. I also forgot to mention that you should check the pressure relief valve and spring in the oil pump also.
Irv
01-30-2005 15:12:39
 Re: Super C oil pressure in reply to justin w, 01-30-2005 12:43:03
I am surprised that the plate on the oil pump is alumimium. The plate in my H is cast iron and i put it on a surface grinder to clean up the headspace. I worked on oil pumps quite a bit and a .001 increase in headspace can drop oil pressure quite a bit. Irv
