Scavenger valve in TD-6
Dennis Freytag
01-30-2005 16:56:26
Have fuel filling up oil reservoir in my TD-6 injection pump. Is the problem in the Scavenger valve? Where can I get a new one? Thanks, Dennis
dej(JED)
02-01-2005 08:00:58
 Re: Scavenger valve in TD-6 in reply to Dennis Freytag, 01-30-2005 16:56:26
I will sell you one for $1000, but you have got to take the whole machine.
Farmaller
01-31-2005 16:40:06
Most of the time the leak is coming from the top of the plunger where the big nut is located. I usually replace them with o-rings from hardware store. If that doesn"t fix it, it could be the distribution block seal has blown out.
DWV
01-31-2005 07:32:46
The primary and scaveging pump drive from shaft rear of injection pump.If scavenger pump not working or seal ( originals used packing) on shaft is leaking it will cause the problem.Couple other things in pump also but get to complecated
to explain.
JonT
01-31-2005 06:31:30
Dennis,
I have the same problem on my MD, and I would like to get to the bottom of it as well. I don't think its the scavenger valve, I think its a seal or an o-ring somewhere in the main plunger.
