Wrench for Water Pump on M
Charles Park
01-31-2005 06:32:21
The service manual says use wrench 11858D to tighten the packing nut. I do not want to damage the nut by usisng vice grips. Any ideas as to where I can find the wrench?
CNKS
01-31-2005 19:27:30
 Re: Wrench for Water Pump on M in reply to Charles Park, 01-31-2005 06:32:21
The nut on the H is 7/8, I assume the M is the same--a stubby combination wrench, using the open end will work, enough to tighten anyway, a little clutzy but works.
Hermit
01-31-2005 18:21:41
If you're any good with a welder, you can make one with a large flat washer and a flat piece of metal. I made one and it will probably outlast me.
Charles Park
02-01-2005 04:14:58
 Re: Wrench for Water Pump on M in reply to Hermit, 01-31-2005 18:21:41
Now this is an idea! No wonder we are the country that has gone to the moon and back! Thanks. Hope that you outlast it.
JohnG(TX)
01-31-2005 12:20:29
Look on eBay. I see these wrenches come up from time to time. I think I got a couple of them from there. It is just a stamped steel spanner-type wrench. The type was also used on the F-20 for the tranny input and PTO output shaft seals. I found a set of Williams spanners on eBay which I use on the tractors.
JG
Novel Idea Guy
01-31-2005 08:43:01
1958 or thereabouts, meaning the special wrench is almost certainly no longer available.
Wrong Again!
01-31-2005 15:33:48
 Re: Wrench for Water Pump on M in reply to Novel Idea Guy, 01-31-2005 08:43:01
Sorry, spanner wrenches are available, even if you don't find the IH original.
John M
01-31-2005 06:40:49
I just use a hammer and brass rod and tap it tight.
