TA THROW OUT BEARING??????
K.W.
01-31-2005 16:02:21
HI ALL, How big of a job is it to change the TA throw out bearing and how costly????? ? Thanks
captaink
02-01-2005 09:14:57
 Re: TA THROW OUT BEARING?????? in reply to K.W., 01-31-2005 16:02:21
How long has it been since it was apart for TA work the last time? The bearing probably won't cost mutch, but...like others, is this all you will fix, no matter what?
To fix the complete TA it takes a double split, and you will probably end up putting in a lot of parts like clutch, pressure plate, live power tube out of the pressure plate, TA clutches (both direct and overrunning) and possibly even more parts while you are in there. If you are thinking of doing it yourself, get a shop manual (IT or Blue Ribbon) and study what all needs to be done. It is not terribly difficult, but does take time, patience, and the equipment to do the double split. I would suggest pricing out the parts I mentioned plus any others that have been suggested and go from there.
Allan in NE
01-31-2005 17:04:39
KW,
Don't go in there with the idea that you are gonna get away with just replacing the darned bearing. Things just don't have a way of working out that way.
Granted, it runs all the time and is prone to a lot of wear. But the rest of the system has just as many hours on it as that darned bearing has.
It's better to figure the worst, I would think.
Hope you get it figured out,
Allan
JOSSETTE
01-31-2005 16:43:02
BIG-BIG JOB. SPLIT THE TRACTOR IN HALF. TWO JACK STANDS AND A OVERHEAD CRANE WORKS THE BEST TO ROLL THE BACK HALF. PARTS ARNT TO BAD AND THE LABOR WILL BE A LOT OF MONEY.
JOSSETTE
01-31-2005 16:42:45
RickB
01-31-2005 16:09:14
Are you paying for the labor or doing it yourself? Are the pressure plate fingers damaged? I would be pretty surprised if they aren't. The tractor will have to be split, are you prepared to fix whatever else is uncovered? Cost could run from just the cost of the bearing on up. Anyone giving a firm answer to your question as posed is guessing.
