Recommended Plugs for my International A? (2 part
MACE
02-01-2005 04:15:04
This is a two-part question.
A What are the recommended flavor of spark plugs I should be using in my A model International?
B Has anyone ever heard of an International A with a Fairbanks Morse Mag installed? Mine has one. The question would be, that I suppose this was installed down the road as a replacement for the original?
Thanks,
MACE
MACE
02-02-2005 05:59:24
 Re: Recommended Plugs for my International A? (2 p in reply to MACE, 02-01-2005 04:15:04
Thanks guys for all of the help and advice thus far.
MACE
sammy the RED
02-02-2005 11:17:02
 Re: Recommended Plugs for my International A? (2 p in reply to MACE, 02-02-2005 05:59:24
Your Welcome. ;o]
Dave Sherburne, NY
02-01-2005 19:13:52
I use AC C-86
captaink
02-01-2005 10:05:21
If I remember right, the Champion D-16 was the plug that recommended at the time the letter series was made. The Champion name has been under fire for being a poor quality plug off and on the past 15 years. Personally, I still run the Champion D-16. I have run equivalent plugs in AC, Autolite, and Mortorcraft. I’m not sure which one is the best as they all seem to last about the same for me.
I also run ethanol blended fuel which seems to help with the carbon problems, and I still work the tractors that I have when I run them. If you don’t work the tractor then the hotter plugs suggested by others is the way to go.
CNKS
02-01-2005 09:50:44
A--same as the others, little used tractors do better with a hot plug, D21 or equivalent, I believe there is a D23. D15's are fine in a working tractor. B--The OEM mags are still available as are parts to repair them. I think the guy found the FM mag would fit and work so he used it.
sammy the RED
02-01-2005 06:52:03
I use Champion D-21 in the 706 and 350.
Use Champion D-15Y in my Super M-ta.
farmallkid From Ont.
02-01-2005 06:22:38
In almost all of ours we have AC DELCO, We put champions in our F-20, then we had to get it timed and the guy said to never buy champions cause there junk.
champion
02-01-2005 05:58:15
A. Champion D-21. Some don't like them, have/had 7 Farmalls, all came with Champs, run what you want. B. Don't know.
steveormary
02-01-2005 10:30:48
 Re: Recommended Plugs for my International A? (2 p in reply to champion, 02-01-2005 05:58:15
Used Champion D21 in my gas tractors and Sta-Bill in the on farm gas barrel. Tractors didnt have to work hard altho got warmed up to operating temps most of the time.
steveormary
