Re: Super H T what
DPH
02-01-2005 06:01:49
CNKS has a point, but I know a guy that pulls his M at around 95 hp, and I am sure there are a lot of guys that do the same thing. A Powerstroke, obviously, would be way above that. But like the other posts said, if you don't pull it, use it with the implements it was intended, and don't weight the heck out of the rear end, you won't need to touch the tranny or the rear end, the tires will simply spin. It is your $, you would have a neat conversation piece if that's what you are after, but I wouldn't worry about shelling out the tranny or rear end. At least, no with the first M, if you go through it pretty fast, then maybe :)
CNKS
02-01-2005 08:42:11
 Re: Super H T what in reply to DPH, 02-01-2005 06:01:49
I imagine the pulling guys are used to replacing parts, just part of what they are doing. As stated, if you ar actually farming with it and don't overload the rear, it's ok. I always remember the 460/560 problems with only maybe 10 added hp, and wonder how those with the modified engines make their trans/rear gears last.
