454 problem
Jim Bruner
02-02-2005 09:27:09
This tractor is locked up in forward, low, and first gear. How do I unlock it.
Thanks Jim
jwb
02-08-2005 09:06:28
 Re: 454 problem in reply to Jim Bruner, 02-02-2005 09:27:09
where can I find a lubercation chart? Ie what kind and type of fluids to us.
Thanks
jwb
02-04-2005 08:54:48
thanks
RAS
02-02-2005 10:12:03
The first thing I would try is go under the tractor on the left side with a little bar and see if you can move it back to neutral. Just make sure it is on flat ground so it does not move when you try this. Don't want to get you run over.
