Need Little Genius Trip lever and tail wheel
Adam Davis
02-02-2005 15:49:14
I have a little Genius #8 plow on rubber that I plan to restore and use but it is missing the trip lever and braket to hold it down. I would like to find these pieces to make this plow usable again. I also need the rear rim "tail wheel" and one of the front rims. I have a set of truck rims on the front now, doesn't look right. I have posted this before but at the time was not able to follow up on it.
Thanks for all your help.
Adam Davis
MagMan
02-02-2005 17:26:48
 Re: Need Little Genius Trip lever and tail wheel in reply to Adam Davis, 02-02-2005 15:49:14
What does a little genius plow look like? I have a bunch of old plows lying around. I need a tail wheel and hub for a set of 3 bottoms my self. But I dont know what kind they are except that they are IH.I may have the trip for ya if I can figure out what these are. JON
Adam Davis
02-02-2005 17:39:12
 Re: Need Little Genius Trip lever and tail wheel in reply to MagMan, 02-02-2005 17:26:48
If they are IH pull type plows they are most likely Little Genius models. I added a link to a picture of a #8. Some of the #8's had steel wheels too. Mine has rubber though, trip lever is the same though. It is loated next to the drive wheel on the drivers left side.
Thanks I appreciate the help.
Adam Davis
MagMan
02-02-2005 17:51:00
 Re: Need Little Genius Trip lever and tail wheel in reply to Adam Davis, 02-02-2005 17:39:12
OK this is what I have . I have one 2 bottom thats on all steel wheels. And two One 2 bottom and one three bottom that are on rubber. The ones on rubber have places for hydrolic cylinders and a trip by the wheel with a bent piece of metal strapping around it. WHAT DO I GOT AND WHAT DO YOU NEED IF THIS IS WHAT YOU WANT. i LIVE IN NY JON
Adam Davis
02-02-2005 20:17:32
 Re: Need Little Genius Trip lever and tail wheel in reply to MagMan, 02-02-2005 17:51:00
I need the trip lever (has about three 90 degree bends in it with a little roller on the end that engages the clutch on the hub) and the bracket that holds the lever on the axle (bolted on with two bolts). The lever is actuated with a rope usually.
Adam Davis
Nebraska Cowman
02-02-2005 16:48:20
I think I can find the wheels. But don't have any parts plows right now to steal a lever off from.
Adam Davis
02-02-2005 16:55:31
 Re: Need Little Genius Trip lever and tail wheel in reply to Nebraska Cowman, 02-02-2005 16:48:20
Do you know what you would want for them? Especially the tail wheel. Also do you know what shipping would be to send them to Southern Central Illinois (Oblong, Illinois 62449)?
Thanks
Adam Davis
Nebraska Cowman
02-02-2005 17:20:06
 Re: Need Little Genius Trip lever and tail wheel in reply to Adam Davis, 02-02-2005 16:55:31
I'll have to look tomorrow and see what condition they are in. Drop me an email and I'll get back to you.
