674 engine block
Yellott Canby
02-03-2005 19:45:37
Hello, Went to put new sleeve seals in my 674 as water had been getting into the oil. Got a sleeve out and was shocked to see a huge crack running down both sides of the jacket around the sleeve, all the way down to the main bearing. I believe the block is done. Was wondering the best place to get a used block. It is a D239 diesel. Thanks YC
JOSSETTE
02-04-2005 15:27:14
 Re: 674 engine block in reply to Yellott Canby, 02-03-2005 19:45:37
worthington ag parts in minnesota. 1-800-533-5304
give them a casting num off of your block. they are usually about $600-$700 for a block. they magnaflux it all. $3000 to $4000 for a running motor. good luck
Yellott Canby
02-07-2005 17:54:07
 Re: 674 engine block in reply to JOSSETTE, 02-04-2005 15:27:14
Thank you all for you advice. I will have to do some thinking about what to do next.YC
El Toro
02-04-2005 08:51:49
Try Draper Tractor Parts at 1-800-967-8185 and Rice Equipment at 814-226-9200. You can try Leader's Farm Equipment at 814-652-2809, both of these company's are in western PA. Hal
JOSSETTE
02-03-2005 19:51:00
WOW --thats impressive!! check the head also in between the valves on that cylinder...
