Tach Cable
PAULIH300
02-04-2005 13:22:46
Where does the tach cable on a 300U route? I would like to tuck it behind the right items,but I cant see any "clean" way to do it.
janicholson
02-05-2005 16:14:46
 Re: Tach Cable in reply to PAULIH300, 02-04-2005 13:22:46
On our 350U, a 1957, (starting at the dist.) it runs parallel with the hyd. pipes then curves upward and dissappears under the fuel tank crossing about mid tank(as I recall), the cable then snakes up the left side of the tank rear corner (under the seam, I think) then connects to the tach. left sheetmetal off helps some.
