Q for Allan in NE or Hugh McKay
Stickler
02-05-2005 00:56:21
Hey buds, any experience operating a 666 or equivalent in really really cold weather? We just got thru a cold spell of -40 plus, and my gear drive gas 666 would take well over an hour for the hyds to warm up enough to do anything. No 3pt on it, so can't use that to excersize it, just the pwr steering and the loader. Starts just fine when plugged in, but the hyds take forever to warm up. Is that normal?
Oh yeah, FYI, on the 1850 loader, it'll lift my 1600lb bales about 6", but won't even budge the 1900 pounders (as weighed by the neighbour that baled them.) them i have to chain and drag. I did verify 1600psig at the pump.
Allan in NE
02-05-2005 14:46:19
 Re: Q for Allan in NE or Hugh McKay in reply to Stickler, 02-05-2005 00:56:21
Hey Stick,
Do you have a pickle fork for that bucket or do you just use a different bucket entirely for the big bales?
Allan
third party image
Stickler
02-05-2005 22:39:58
 Re: Q for Allan in NE or Hugh McKay in reply to Allan in NE, 02-05-2005 14:46:19
yeah, I got a spike for the big rounders, 3" solid steel..... .....it was just as sucky in the summer lifting the big ones..... i was more curious how long it should take to get things running normally.....as in circulation.
Stickler
02-05-2005 22:40:58
 Re: Q for Allan in NE or Hugh McKay in reply to Stickler, 02-05-2005 22:39:58
And.....the reason i asked Hugh is he farmed in canada, where it actually gets COLD!
Hugh MacKay
02-06-2005 03:06:13
 Re: Q for Allan in NE or Hugh McKay in reply to Stickler, 02-05-2005 22:40:58
Stickler: Let me assure you not all of Canada ever gets that cold. Here in SW ON they consider anything below 0 F to be extreem. Where I farmed in Nova Scotia 0 to -20F was the norm. Only twice in my life time have I seen -40F. If I never experience it again, I will not be disappointed.
I did however experience same problem with my Farmall 560D as you are having with your 666. Ice crystals block filter to a point that the pump becomes starved for oil. It can completely ruin the hydraulic pump. Hydraulic pumps don't last very long without oil, as it lubricates pump as well as performing hydraulic function. From your discription of starting and warm up, my guess is that your hydraulic pump is allready ruined.
I had a 2000 loader and over the years had it on both 560 and 656. It would lift more on 656. On either tractor it played with 5x6 round bales. From a lift stand point I don't think there was much difference between 1850 and 2000 loaders. I know I had a neighbor couple years back load some items on a truck for me with his 444 and 1550 loader. These were all pallets, and all weighed 1500 lbs. plus the pallet. I can assure you, pallets are just as difficult as round bales. Weight is one matter, but just as important is how far beyond pins of loader bucket that weight is.
Hugh MacKay
02-05-2005 13:58:37
Stickler: I guess I'm a bit late, been away today, but since you did co-address me, you already have very good answers. Moisture in the transmission hydraulic oil is more than likely the culpert. Don't put off changing it either. Every time you start it cold you are doing damage to hydraulic pump. You may already be too late on that one. 666 with 1850 loader should play with the largest of round bales.
RAW in IA
02-05-2005 10:24:44
A few years ago the airport here had a 666 they used for moving snow. One winter the hydraulics almost quit (hitch was real slow). I checked the filter, and it lookied like it had never been changed. Even the bypass was plugged. Changed hy-tran and filter and it worked real good again.
Allan in NE
02-05-2005 06:15:52
Hi Stick!
Where ya been? Haven't seen ya on here for awhile. :>(
Wow! -40! Dat's too derned cold!
Have you tried the space heater under the belly trick yet?
Nebraska Cowman uses a Hydro 70. Maybe he'll jump in here and share a few pointers with us.
Allan
RustyFarmall
02-05-2005 06:57:00
 Re: Q for Allan in NE or Hugh McKay in reply to Allan in NE, 02-05-2005 06:15:52
Allan, that space heater under the belly trick is a darned good idea for any tractor that has to be used in extreme cold weather. No matter what color it is.
Allan in NE
02-05-2005 07:12:33
 Re: Q for Allan in NE or Hugh McKay in reply to RustyFarmall, 02-05-2005 06:57:00
Mornin' Rusty,
Yeah, at -40, there just 'taint much of anything that is going to move! :>)
I always liked to use the space heater rather than the #2 diesel burning in an open feed pan. Even tho it worked well, the darned diesel smoke would always turn the underbelly black.
But, you do what you have to do to get those critters fed; they're cold too and need the feed to keep warm.
I used a John Deere Chuck wagon to feed silage with and learned real fast that you don't leave the wagon full of feed overnight. Darned moisture in that silage would freeze the floor & conveyor chains down. :>(
Allan
Hugh MacKay
02-06-2005 03:21:29
 Re: Q for Allan in NE or Hugh McKay in reply to Allan in NE, 02-05-2005 07:12:33
Allan: At -40 you just hunker down and hope tractor doesn't start. I have a friend in Nova Scotia in the logging business. He claims at anything below -30F, he just phones his crews and tells them to sit by fire side for the day.
He claims that after spending 3 hours getting 4 diesels going, then almost a 99% chance of breaking something in extreem cold. Couple that with fact that men using chain saws below -30F can't work hard enough to keep warm, thus the crew usually heads home by noon. When you piece all this together, your mony in to sit by fireside for the day.
Allan in NE
02-06-2005 07:38:46
 Re: Q for Allan in NE or Hugh McKay in reply to Hugh MacKay, 02-06-2005 03:21:29
Hi Hugh,
Well, that might work with trees, but you don't let cattle go hungry because it is cold outside. Cattle need the feed to generate warmth.
Coldest I've ever seen is -47. Doesn't matter, cattle still got fed, cows still got milked, ice gets chopped outta the tanks. Rest of the day is spent bedding the darlin's with straw.
Things just take a heck of a lot longer when it is cold is all.
Allan
Stickler
02-09-2005 13:27:48
 Re: Q for Allan in NE or Hugh McKay in reply to Allan in NE, 02-06-2005 07:38:46
Exactly. Doesn't matter how damned cold it gets, they still need to eat. Can't shut her down. And that's why i have a gasser, so it'll at least start. I have electric waterers, so that isn't a huge problem, but moving the bales is. Thankfully, i have small squares as well for the horses that i can pitch by hand if need be.
The oil is not milky, and the filter was changed in the fall. I guess I'll have to pull it again.....
Hugh MacKay
02-06-2005 17:34:42
Allan: Does farming like that make money?
JJK
02-05-2005 05:14:20
I'm not either one of the guys your askin for but I am familliar with these tractors. Most oils at -40F are real stiff. Hy-Tran will absorb water to an extent (best on the market). I would check your oil to see if it looks cream color and even loosen the drain plugs to see if any water comes out. If so then change the oil and filter. It just sounds like the oil is froze up enough that the pumps have a hard time sucking up any oil. Damage to the pumps may have occured from running an hour without getting any oil to lube them (just a warning to you) making the problem worse. About the lifting the bales you need a new relief valve. Get a 2100 or 2300 pound relief and you'll have no problem lifting those bales.
jb2
02-05-2005 07:19:49
 Re: Q for Allan in NE or Hugh McKay in reply to JJK, 02-05-2005 05:14:20
Hi, my brother did have a 434 with 1501 loader on it and in -30F weather it would take 30 minutes before the loader would lift and that was with Hytran hydraulic oil. Now he has 495 with 2250 loader and it requires no warmup but lifts slower until Hytran warms up.
Re loader lift capacity, does your loader have a separate hydraulic control valves or is it plumbed into the tractor remotes. If it has a separate control valves the relief valve spring is contained in the screw on cap that is beside the control levers.
I DON'T recommend this unless all your hydraulic hoses are 2000 to 3000 psi rated but you can screw off the cap on the hydraulic control valves and put a couple of dimes behind the spring and this will increase the lift capacity of the loader. Also you require extra weight on the rear of the tractor for stability.
Becareful with those large bales.
JB2
