silver dimond engine
farmall4606
02-05-2005 06:43:42
can anyone tell me the horse power and general specs. on the silver dimond engine
olderguy
02-05-2005 22:09:59
 Re: silver dimond engine in reply to farmall4606, 02-05-2005 06:43:42
silver diamond engine was an in-line 6 cylinder used in I.H. trucks... for more info go to Oldihc.org
Dave (IL)
02-05-2005 10:11:21
Was an International truck engine. I've seen occasional references to it. Some I think in the IH history site at Madison WI.
Here's a link on this site.
JOSSETTE
02-05-2005 07:07:45
never heard of that..what is this motor in?
I know there was a diamond rio engine in 30 and 40 but that was in a truck
just curious
Al in Mn
02-05-2005 19:04:30
 Re: silver dimond engine in reply to JOSSETTE, 02-05-2005 07:07:45
The Silver Dimond engine was also used on the 127 and 141 combines
farmall4606
02-05-2005 11:08:53
i found the motor in a junk yard . it looks the same as a 460 motor i"m curious about the specs on it and if it is interchangeable
CNKS
02-05-2005 12:24:47
 Re: silver dimond engine in reply to farmall4606, 02-05-2005 11:08:53
I get the silver diamond and the black diamond truck engines mixed up. One or the other is basically the same as the one used in the 460/560 tractor series. As to putting it in a 460/560, someone else will have to tell you if you can mount it in the tractor and whether or not the "bell housing" will bolt up to the TA housing. The tractor engine has a governor, I doubt if the truck engine even has a place for one. The tractor engine has sleeves--truck engine??. The camshaft is probably different. But, the block is the same, far as I know. The engine in the trucks was called a C220, in 460 tractors a C221, the 560 was a 263? The 3 9/16 bore in the 460 engine rounds to 221 cu inches, not 220, don't know why it was called a 220.
JonT
02-05-2005 16:29:13
 Re: silver dimond engine in reply to CNKS, 02-05-2005 12:24:47
The Silver diamond (1949) was 220, or 221 to be accurate, as you said, but it had 220 stamped in the bottom of the oil pan. The Black Diamond was a 241, and came out later, 56 or 57 I think. It was essentially just a bored out Silver diamond with a few other minor differences. I'm not sure but maybe the crank is different, that might explain the difference in displacement.
CNKS
02-05-2005 18:40:37
 Re: silver dimond engine in reply to JonT, 02-05-2005 16:29:13
thanks!
JOSSETTE
02-05-2005 11:35:16
dont know much about it and the one that would know past on 3 yrs ago. see if there are any motorheads on the other forums==you might get lucky.
Allan in NE
02-05-2005 07:37:13
Mornin',
When I was a boy the neighbor across the road had one of those Dimond Rio trucks that he let us use during potato harvest.
I still believe to this day that it was the grandest truck I've ever laid eyes on.
Allan
El Toro
02-06-2005 09:37:27
 Re: silver dimond engine in reply to Allan in NE, 02-05-2005 07:37:13
Hi Allan, The government used a lot of Diamond
Reo engines in their trucks until they went with
a multi-fuel engine made by Continental Motors.
It must have been politics since Continental made the tank engines too, even when they went to all diesel engines. The multi-fuel trucks were outlawed in Germany do to so much exhaust smoke.
Then they purchased the MAN diesel trucks that hardly smoked. We ran a lot of those Reo engines on the dynamometer stand for endurance. Never had a problem with them. Hal
