460engine swap
arky
02-05-2005 07:37:07
Will a 1959 264 truck engine go in a 460?
ChadS
02-05-2005 08:40:22
 Re: 460engine swap in reply to arky, 02-05-2005 07:37:07
Yes. Use the tractor flywheel, clutch, front timing cover to add the governor assembly. Use the tractor intake as well. It is a bit stronger than the old 221, quite a bit stronger. Good swap if the engine is good. The head is like a full ported version of the tractor head kinda like a factory high performance upgrade. Hope this helps, ChadS
