Lost Spark!!!
Spud
02-05-2005 20:08:53
Bought a Farmall 340 was not runnung Changed it from 6 volt to 12 volt Installed new battery points consender new rotor cap new coil new rotor new consender new plugs new plug wires But it wont run !! When you crany the engine you have weak spark at points and it goes away after a few cranks But no spark at plugs ??? Whats the malfunction??? I have reset the points several times checked the dist! lost!!!
CNKS
02-06-2005 12:27:57
 Re: Lost Spark!!! in reply to Spud, 02-05-2005 20:08:53
If you replaced all the parts before you tried to start it before, try putting the old condensor back on, new ones are sometimes defective -- happened to me once.
John M
02-06-2005 07:01:18
By chance did you put a a 6 volt coil on it?If you used a 12 volt coil,did you get one with a built in resistor?I personally have never burnt up a set of points on a 12 volt coil,and some will argue that point,but I have never burnt a set of points on a 12 volt coil with no resistor,but I use a 12 volt coil with a built in resistor on all my 12 volt conversions.Anyways,sounds like your coil is maybe the culprit.
Russell
02-05-2005 21:24:14
Hi, im not sure but try a rezister between the coil and the points.
Bob
02-05-2005 21:45:05
 Re: Lost Spark!!! in reply to Russell, 02-05-2005 21:24:14
An ignition resistor (ballast resistor) is ALWAYS used between the ignition switch and the coil, NEVER between the coil and the points.
JOSSETTE
02-05-2005 20:40:05
did you switch the polarity at the amp gauge???
neg post to the key and the pos post to the alt
JOSSETTE
02-05-2005 20:23:35
do you have a wire going from the positive of coil to the start relay. need resistor between the coil and ign switch so you dont burn up the points. i wiil give you aa full layout of where everyhting goes if this does not work.
Bob
02-05-2005 20:17:04
Hook a 12 Volt test light to the (-) primary coil terminal connected to the points, and crank the engine over with the ignition "ON". The test light should flash "ON" and "OFF" as the points open and close.
If the light NEVER comes on, you have no power to the coil, a bad coil, points that aren't opening or a short in the points/condensor area.
If the light never BLINKS OFF, you have an open circuit between the coil and the points, or dirty points that are not making contact.
