Novice with Farmall M Lift All Problem
Norm in CA
02-06-2005 01:30:24
I have a Farmall M with a lift all problem. It will not release the pressure to lower the 3 point hitch. It started out by getting harder and harder to push the control rod all the way forward to release the pressure. Now, no matter how hard I push, the lever on the side of the tractor will not go all the way forward to release the pressure.
Thanks in advance for any help you can give me.
Norm
MAGMAN
02-06-2005 04:45:10
 Re: Novice with Farmall M Lift All Problem in reply to Norm in CA, 02-06-2005 01:30:24
Not knowing what you have for hydrolics. I would say that you need to bleed off a valve somewhere. If you have a belly pump try the left Hand rear pipe coming out of the pump while sitting on the seat. I had to do this to my H last week . Maybe there is an easyer way but alls I did was loosen up the pipe plug and let some pressure and a tiny bit of fluid off and she would go down after that. JON
Norm in CA
02-07-2005 11:37:01
 Re: Novice with Farmall M Lift All Problem in reply to MAGMAN, 02-06-2005 04:45:10
Thanks Jon.....It worked like a charm.
