Coolant Leak?????
RETCOL
02-06-2005 04:36:15
I have all my old Farmalls sittng in the shed on cardboard. I noticed after a real cold period that it appears the M,H, and Super H had antifreeze and water stained on the cardboard. Is this common as a result of real cold weather or do I have a seal that needs to be replaced?
RustyFarmall
02-06-2005 04:46:55
 Re: Coolant Leak????? in reply to RETCOL, 02-06-2005 04:36:15
Cold weather can sometimes cause leaks to show up that would not have shown up if it hadn't got so cold because everything contracts in cold weather. It would still be a very good idea to try to determine where the leak is coming from, most likely you will just need to tighten up some hose clamps.
FRANK
02-06-2005 14:32:48
 Re: Coolant Leak????? in reply to RustyFarmall, 02-06-2005 04:46:55
THATS INTERESTING ABOUT THE LEAKS. I NOTICED A LITTLE ANTI-FREEZE UNDER BOTH MY "SM" AND "SMTA" THAT WERE PARKED IN THE SHOP. I HAD NOT NOTICED ANY LEAKAGE BEFORE PARKING THEM FOR THE WINTER.
