Another Question for ChadS or those who know
Dave in CT
02-06-2005 09:34:03
Well I got the new used distributor in my '47 H with the HEI recurve kit sptings - what a difference! Now that I'm able to measure some advance with a dynamic timing light, I was wondering how close I was to the optimum hp. I thought it was in one of your posts, Chad, where you listed an advance of 35-something degrees for maximum hp as shown on the dyno. I searched for the post but couldn't find it. Does anyone have figures for advance degrees that produce the maximum hp on an H as shown by the dyno? TIA
Chip
02-07-2005 20:09:29
 Re: Another Question for ChadS or those who know in reply to Dave in CT, 02-06-2005 09:34:03
Depends on the octaine of the gasoline. Are you sure you have top dead center? Screw a stop in the number one sparkplug hole,rotate engine until stop touches piston then rotate back until stop touches again, halfway between the two will be top dead center. Timing marks can be off due to mass production. Hold a Degree Wheel up to the front of your front pulley and see what degree marks you've got 20 degree's? 30 degree's?, then you'll know what settings are best for your fuel, engine, combination. Rev the engine up to get the springs,weights out, now you can set the total timing. 38 degree's good on a racing chevy, but I back it off 2 degree's to make it live longer. ChadS has a web page check the tractor pulling page. Good Luck!
Dave in CT
02-07-2005 21:23:40
 Re: Another Question for ChadS or those who know in reply to Chip, 02-07-2005 20:09:29
Thanks for the reply. I marked and confirmed the full advance point I have now and calculated from the diameter of the pulley and the distance of circumference (arc) from the TDC and the full advance mark and found that I've got about 35 degrees now. This is fine as far as I'm concerned but I was just curious as to what max hp points people have found. I'd like to look at Chad's tractor pulling page. Where is it?
Chip
02-08-2005 09:10:39
 Re: Another Question for ChadS or those who know in reply to Dave in CT, 02-07-2005 21:23:40
On the Tractor Pulling forum the title is Chads new business www.chadsantiqueperformance.bravehost.com
