Breaking in a newly overhauled engine.
victor
02-06-2005 20:22:14
what is the best way to break in an overhauled engine with out a dyno? what is the correct procedure for doing this?
gusc
02-07-2005 20:53:00
 Re: Breaking in a newly overhauled engine. in reply to victor, 02-06-2005 20:22:14
Josette and steve know what they are talking about.
The only thing that needs breaking in is the rings and cyl walls. The rings must have enough pressure to expand against the cyl walls to seat well and any no load condition will not do this.
Do not run the engine at idle for more than just a few seconds to look for leaks.
DO NOT EVER run an engine at high idle or high speed without a load. This will ensure that the rings never break in and that the cyl walls will have a permanent glaze that will result in poor compression and high oil consumption. I understand that there is one exception to this for racing engines. Never had anything to do with them so can't say one way or another.
Run it for about a half hour under medium load and watch the temp. Do not let it overheat for more than a minute or two. Sometimes new engines will get hot from blowby but only for a short time. Airplane engines do this. Once the rings set that will end, usually in less than a half hour..
John M
02-07-2005 04:24:04
If you dont have any way to work it,let it sit and run at different rpms for oh sya an hour os so then take it up the road in 5th gear.Look for roads with hills and take them at varying rpms,or if you have a hilly area near you that you cna safely take your tractor drive it over there.A few guy around here have ATV trails that we can safely take one on,but its gotten worse over the years and is getting harder to go down those so we just ride up and down the road for a few hours.
JOSSETTE
02-06-2005 21:11:02
the tractor vet is right
my grandpa used to put a 1/2 loaded hopper(200 bush) behind it and ran it down road ( up hill both ways)==to seet the rings he said. I dont recall having any problems. got it hot changed oil and filter and off to work.
the tractor vet
02-06-2005 20:32:45
Light to medium CHORE work for the first thirty hours. Change oiland filters at the frist ten hours and againat the thiry hour mark and then go for the regular service intervals.
CNKS
02-07-2005 08:00:25
 Re: Breaking in a newly overhauled engine. in reply to the tractor vet, 02-06-2005 20:32:45
Currently overhauling my 460 engine. I only have 2 acres--would take me two years to put 30 hours on it. I'm considering asking a neighbor if he would let me bushhog some of his weeds, but I was only thinking 2-4 hours of use, along with running it up and down the road at different speeds along with idling it at varying speeds??
the tractor vet
02-07-2005 08:40:40
 Re: Breaking in a newly overhauled engine. in reply to CNKS, 02-07-2005 08:00:25
THen go play on a neighbors farm he would probably enjoy your help.
steveormary
02-07-2005 10:25:23
 Re: Breaking in a newly overhauled engine. in reply to the tractor vet, 02-07-2005 08:40:40
we would break them in on a manure spreader. Load,no load. Broke in a Super M plowing alfalfa with a 3 bottom plow. Just run it easy. 2nd gear or mabe 1st sometimes.
steveormary
