red syn gear oil
JOSSETTE
02-07-2005 05:35:59
WOW!!! HOLY CRAP this stuff went high. it more than tripled in price. SORRY i memtioned it. i was not aware it jumped. are you sitting down???
$ 32.00 a gallon. times 10 gal. WOW==HOLY CRAP!!
the $ 27 a 5 gal sounds pretty good. I have the receipt when i put it in my big truck. $125.65 to do the trans and two rearends ( about 13 gal) plus tax. SORRY fellas
TDK
02-07-2005 09:20:22
 Re: red syn gear oil in reply to JOSSETTE, 02-07-2005 05:35:59
I'll have to agree with Doug. The cost is probably justified in a semi but not an old tractor that we use or show occasionaly. I still didn't expect the high cost though. P.S.- IH Hy-Tran is around 35 - 40 dollars for 5 gal. The best reason for using it in trans/diff. is if tractor has a T/A. I tried a generic hyd. oil with a T/A a while back, T/A would not work. Changed to Hy-Tran and it started working. I wouldn't have believed it if I had not seen it for myself. I don't think the T/A will work well at all with gear oil either.
Doug in OR
02-07-2005 06:24:09
I can get AMSOIL Synthetic for slightly over $100 per 5 gallon pail. Not cheap when compared to mineral oil, but cheaper than you are talking.
Personally, I would not use any of those super-premium oils in a classic tractor. The cost just does not justify the use in those applications.
JOSSETTE
02-07-2005 10:32:53
 Re: red syn gear oil in reply to Doug in OR, 02-07-2005 06:24:09
ams oil is the same thing maybe a little better quallity too. forgot about amsoil
Dave in CT
02-07-2005 06:04:59
Thanks for posting the update. Probably won't go that route though it sounds like some pretty darn good gear oil. What brand and type was it?
JOSSETTE
02-07-2005 06:15:21
 Re: red syn gear oil in reply to Dave in CT, 02-07-2005 06:04:59
it is a Valvoline 75-90. you can get it a carquest for sure. just called them
