international 460 governer adjustment
mizzou
02-07-2005 07:14:38
My 1960 international 460 doesn"t have any minor adjustment to the throttle. It seems to be all or nothing. Also when the governer kicks in, it makes the engine rpm go way up. Can both of these problems be governer adjustment? (or malfunction)
CNKS
02-07-2005 07:54:43
 Re: international 460 governer adjustment in reply to mizzou, 02-07-2005 07:14:38
I had the same problem, I pulled the governor, and replaced the "wear" parts, that is bearings, etc, don't remember all the details, I also replaced the external spring, and adjusted it according to the service manual. This was accompanied by a carb overhaul, which it needed anyway. A shotgun approach, but I believe the problem was the spring, along with the adjustment. I really did not find anything wrong inside, perhaps cleaning it helped.
