Shaggy
CNKS
02-07-2005 09:52:16
I didn't see your post about the touch control unit, which is now on page 3. My units only have one cover, I believe it's the rear one you are talking about. On my C I had a heck of a time getting the cover off -- it was stuck pretty good. I used a thin, rigid putty knife, the odd shaped one, forgot what they are called (at any paint store), and carefully tapped it in with a hammer at several places, finally broke loose, no leaks upon reinstallation. As to the screw, I don't remember (as usual), but my parts book shows a "plug and screen, pressure regulator valve orfice", lower right corner of reservoir back plate. If that is the one, remove it. With all the bolts out the cover is just stuck -- I posted on this forum with the same problem about 3 years ago.
Shaggy
02-07-2005 21:48:59
 Re: Shaggy in reply to CNKS, 02-07-2005 09:52:16
Thanks for giving me a shout! I have the whole tractor torn apart in a Buddies garage for painting and I thought I would fix this while it was off. It goes down fine but comes up real slow and almost kills the engine at a idle.
I was told that it out of adjustment on the levers so I just might clean things up and put new seals and try and find new boots for it.
Thanks for the help!! Shaggy
