What's Good Pressure?
JimJim
02-07-2005 13:00:49
What would good hydraulic pressure on a Super-C with a 123 CI engine be? I'm going to install a gauge and check it. What type of gauge should I use? Thank You!!!!
scott#2
02-07-2005 13:26:19
 Re: What's Good Pressure? in reply to JimJim, 02-07-2005 13:00:49
With a load of 300lbs or so on the rear rockshaft (=600 lbs on the touch control rockshaft) and working the hyd lever, the book says pressure should not exceed 1100 - 1500 psi. because at some point in that pressure range the safety valve will open. They ues a SE-1338-A gage. Any quality hi press fluid gage should work good.
This is from the book.
scott#2
the tractor vet
02-07-2005 13:11:10
As for the gauge use at least a 3000 lbs liquid filled and i do not have my books setting here i am not sure but thinking around 1200maybe less. I don't try and keep everything in my head that is why i have so many books.
arod
02-07-2005 13:07:43
TWell, I know my M farmall put out around 80 for oil pressure. Werner guages are pretty good.
